What’s in the Celonis Sustainability Solution Suite?
Kit out your business with these targeted capabilities built to surface and activate impactful sustainability insights.
Production-ready sustainability apps
The Suite puts Celonis’ sustainability-specific apps – ready as-is or customizable to your needs – at your fingertips. They’re easy to deploy and easy to use, purpose-built to orchestrate your most high-value opportunities, including:
- Material Emissions App: Automatically measure, report, and reduce Scope 3 material emissions by intelligently mapping materials from purchasing systems to emission factors.
- Shipping Emissions Reduction App: Calculate carbon emissions using granular operational data, simulate carbon savings, and take proactive actions to reduce emissions.
- Sustainable Spend Management App: Evaluate suppliers’ ESG performance metrics, mitigate vendor risk, and accelerate rating coverage to boost sustainable spend.
- CBAM App Powered by Ventum: Automate reporting and apply mitigation strategies for the Carbon Border Adjustment Mechanism (CBAM) regulation.
Having these capabilities pre-built means your organization can rapidly roll out sustainability optimizations.
AI-powered capabilities
AI development is the next layer of the Sustainability Solution Suite, which you can apply to your custom sustainability challenges. Customers across industries are using AI, powered by Process Intelligence, to build copilots, assistants, and agents that help reduce waste through excess inventory, for example.
Sustainability value and improvement insights can get lost in the unwieldy chaos of unstructured data bound up in PDFs or free text fields – but the Suite has something for that, too. Celonis AI Annotation Builder uses GenAI to triage structured and unstructured data and generate recommendations. This no-code tool allows users to define rules in natural language, so it’s even easier to access and automate AI-driven sustainability improvements.
Annotation Builder is joined in the Suite by Optimization Engine and Network Explorer, which help model and solve more complex sustainability challenges across your supply chain operations using advanced algorithms and total transparency over process relationships.
Pre-defined process data and business context
Talking of transparency, one of the Suite’s most powerful components is the Process Intelligence Graph. This live, interrogable digital twin of your operations enriches raw process data (relating to customs clearance, supplier selection, shipments and delivery, for example) with business context and KPIs relevant to sustainability (such as Scope 3 emissions, supplier rating, and order compliance).
The Process Intelligence Graph also layers in standardized process knowledge from a decade of experience comprising thousands of sustainability deployments. All of which means this data layer allows you to clearly see what’s influencing and impacted by different processes across your operations, so you can take precise action for sustainability optimizations.
Process connectors to critical systems
How does the Suite extract the data to create this enterprise-wide operational view? That’s where connectors come in.
Pre-built connectors make the Suite system-agnostic, quickly and easily ingesting data from your critical source systems. By leveraging the Celonis data layer for existing ERPs to connect to the systems you already use, the Suite creates a common language of how your business runs.
