Five “Dos” for Measuring, Sustaining, and Learning from Changes
1. DO: Build patience into the change framework. Changemaker panelists mentioned that companies frequently give up before a change project has time to take hold. Per Stromberg, perseverance is key for sustained change: “Many companies get excited, then get stranded, even though their desired result was right around the corner.” Carpenter agrees: “Long-term, sustainable change is that: long-term. You have to work at it, put energy in it, and have a good strategy to go get it.” His advice? Keep momentum up by finding a balance between quicker, showier wins and longer-term value.
DON’T: Expect major changes to happen — or stick — after a short-term effort. Overpromising on ambitious deadlines may get execs and stakeholders excited, but adhering to more realistic timelines for changes serves everyone better. If possible, set expectations for a lengthier implementation and long-term post-project support.
2. DO: Establish unique, clear, responsive parameters for measuring success. Our Changemaker panelists agreed that clear goals were instrumental to a change project’s success, and to the larger organization’s perception of the changes. “Always have value in mind, make sure you’re tracking it, make sure you know what your targets are and what’s standing in the way of you getting to your target,” said Carpenter. Think beyond quick wins like training completions or project deadlines (which panelists considered important first steps) and tack on longer-term goals like incremental increases in productivity, efficiency, process adherence, compliance, and utilization. Embrace granularity in your goals, get stakeholder approval, and reevaluate at project milestones.
DON’T: Default to generic or rigid goals for your changes. Your goals help you guide your change management project, measure success, and convince people that the effort is worthwhile — so think critically when setting them, and adjust them if circumstances change.
3. DO: Review progress often and with a consistent cadence. Echoing the advice of our panelists, studies have proven that a drawn-out change process that’s reviewed often has a greater chance at success than a shorter process that’s reviewed less often. Start with the advice of the inventors of the DICE change management framework: for trickier projects, review at least every 2 weeks, and for more familiar initiatives, at least every 6-8.
DON’T: Delay reviewing your progress until the end of the change process. Waiting to check in on your changes until a later date could compromise your project’s success. Changemaker panelist Stromberg also suggested using early data (especially small changes that have successful, quantifiable results) to help build support for later changes among executives: “Once you can show senior management what the impact is…they can really use this to drive change.”
4. DO: Consider your CoE a permanent lever for successful change within your organization. Continue to use your Center of Excellence to monitor adoption and provide ongoing support. Other change initiatives will arise, and the legacy expertise your CoE builds increase chances of success. In the process mining realm, a 2022 survey of Celonis customers found that companies utilizing a CoE were nearly 9X more likely to get a positive return on their investment. Creating and maintaining a dedicated team of experts is a proven way to get projects done more consistently and drive lasting value.
DON’T: Dissolve your CoE to save money. Starting and staffing a CoE can be seen as an ad-hoc compromise, and your organization may want to cut costs by shutting it down or using CoE team members’ talents elsewhere. But letting a CoE continue to build its capabilities over time, both in analysis and execution, will serve the company well in future change projects. Consider it a savvy investment in something inevitable: change.
5. DO: Use insights from this round when change comes knocking again. Make sure to always include a postmortem step so your team can celebrate wins and analyze issues. This is another opportunity to use the power of process intelligence: Changemaker panelist Lehmann reports that Accenture uses Celonis for fact-based findings before, during, and after change projects, in combination with other, more qualitative measures (like surveys). “Decisions are made based on information, and better decisions are based on better information,” says Lehmann.
DON’T: Deprioritize the postmortem if the project went poorly. If you’ve been working on a stressful endeavor, it’s tempting to wrap things up and walk away. But formal postmortems are just as (if not more) important than more active parts of the change process, whether the changes went as well as you’d hoped or not. And when you use process mining to see how your change project impacted or evolved your processes, you’ll be able to identify where any issues arose and replicate or tweak things next time around.
No matter what your change management endeavor is, Celonis is here to support you. To quote one of our Changemaker panelists, Silke Lehmann, once more:
Ready to optimize your own change-management projects using process intelligence? Read more about process mining in change management on the Celonis blog, watch an expert speak about it, or skip straight to talking with a representative.
"It’s never too early and never too late to think about process intelligence. No matter where you are on your journey, if you’re asking, when should I start thinking about process intelligence…the best time is now."
